The best thing you can do is use the 70mm MAF housing with the center bar cut out(obviously leave the sampling tube intact) and use fox-mustang electronics...I got one of the housings for $3 at the local junkyard and figured I'd give it a try...car ran so great afterwards, it extended my usable rpm range and more power through the curve...no idle issues, great off-idle response and a/f was nearly identical. I've heard a lot of people say that the stock mustang 55mm maf will peg at 5v before it becomes a restriction...that is definitely b/s.
I've also seen mustang guys cut out the center bar of the 70mm housings and try to use the stock F2VF electronics and it never works...has to be mustang stuff...(looking for the 3rd digit in the part number to be "Z").
