Originally posted by jaywish
View Post
Anyone Build 302's for MPG? And General Wagon Economy
Well anyway, 250hp is easily achievable with a 302 even without a supercharger, but it would make it easier to accomplish and more efficient. The problem is a supercharger would be pretty expensive.
If you look into it, the cams that are made for economy also have pretty significant gains in torque. With a good aftermarket camshaft you should see gains in all areas. Comp can get you a custom grind for the same price as their numbered cams, just gotta tell em what you want and what you're going to use it with.
GT40P heads will give better economy than standard GT40s because they give better engine compression. A mass air conversion will probably be required to use them, but if you already did an HO conversion that's pretty simple.
You don't really need forged pistons unless you're pushing a hilarious amount of power. Hypereutectic pistons work just fine, and if I correctly understand how they work, they should help with compression as well.
You can also build an AOD to be just about as good as a 4R70W without the computer hassle. If you're not building it yourself, though, it's cheaper to buy a built one.89 Grand Marquis GS.
Originally posted by gadget73 View PostI know of the opposite swap, a 5.0 into a roundy. No idea what he gets for mileage though. The square body does fairly shit things for efficiency, no doubt about that. I get 3-4 mpg better with the Mark VII, and its pushing similar weight with a high mileage engine. I could probably put the driveline out of the Towncar into the Mark and get that same 3-4 mpg improvement.
Originally posted by jaywish View Post...I know "you can't always get what you want, but if you try sometimes..."1985 LTD Crown Victoria - SOLD
