And yes, I remember that part number off the top of my head because I've replaced it on every single Ford car I've had. Some more than a few times.
Running R-134 question
Originally posted by friskyfrankie View Post
So, if the fan speed is not actually slowing down then what is or are the issue(s)? Assuming it is not a weird electrical issue I would think it has to be vacuum related.86 Lincoln Town Car (Galactica).
its a vacuum problem causing the air to come out of someplace else. Pretty much every issue with the climate controls is some sort of vacuum problem. Usually leaks but the check valve failing acts exactly like a leak. its all fairly easy to test, just tedious and those hand pumps will wear you out.What I Own: 1993 Mercury Grand Marquis GS
