where is the Ignition Relay on a 87 302sefi wagon located
Ignition Relay
I checked an 89 diagram and do not see an ignition relay but there is an eca relay. The eca relay is in the block of four relays on the left fender. It is innermost relay in the rearmost set.
Don't know if 87 is identical.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
should be. The ecc relay was in that spot from at least 82+. The ignition switch is in the column. The starter relay is on the passenger fender. I don't think there's a separate relay for ignition other than those.
What is prompting you to look for this relay?03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
It's not a bad idea to replace these relays anyway, for everyone. I was recently working on a bronco II with a stall/no start but-will-start-later gremlin, and the good old fashioned tap-test showed me that the magneto-doodad in the ECM relay was weak. I could tap it once and it would instantly flutter the engine, and tapping it repeatedly would make it stall. The fuel pump relay had a cracked casing and was rusting inside so we replaced that too.
Assuming it's the same color scheme as the Bronco, the green one is the fuel pump relay and the ECM will be the other one that should click when you turn on the key.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
Originally posted by 85crownHPP View PostIt's not a bad idea to replace these relays anyway, for everyone. I was recently working on a bronco II with a stall/no start but-will-start-later gremlin, and the good old fashioned tap-test showed me that the magneto-doodad in the ECM relay was weak. I could tap it once and it would instantly flutter the engine, and tapping it repeatedly would make it stall. The fuel pump relay had a cracked casing and was rusting inside so we replaced that too.
found this diagram http://www.supermotors.net/getfile/8...e/scan0002.jpg still chasing my no start problem
unless that's in reference to the ECC relay on the fender, I don't know what else it could be. I'll pop my hood later and see what wires come off the ECC relay. That may be the droid you're looking for.
