I'm trying to help a friend with her 84 grand marquis. She's had it for a couple of months and it started having "no-crank" issues. Alternator and battery had been replaced before she got the car, they are probably about 3 months old. Finally it was just dead, would not start or run. After I charged the battery it would start and run, but the charging system voltage was low. Pulled the alternator and took it to Advance Auto for testing. It tested good once and bad about 5 times so they agreed to replace it under warranty.
This is where it gets interesting. Advance had changed their stock numbers from when the original alternator had been purchased so they had to look up the new one by year, make and model. The one that they identified as the correct replacement (1st Generation alternator) did not match the unit I removed from the car. I thought maybe she had told me the wrong year and they were able to match it up. It appears to be a 2nd Generation alternator. I installed the new alternator and everything appeared to be OK. Car started and charging system voltage was good. At this point, I thought the problem was solved.
Three days later, it won't start without a jump. The wiring appeared to be in pretty bad shape so I tried to find a wiring diagram. This is when it became clear to me that things weren't adding up. The car is an 84, but the engine is a 5.0L with EFI. The charging system appears to match the 2G wiring diagram except the alternator output goes to the starter solenoid mounted on the passenger's side inner fender instead of the battery.
Any ideas on how I can get this sorted out? Are problems with the 2G charging system common? They had another alternator that had one of the plugs built into the alternator with a pigtail coming off of it. You had to cut off the wiring harness plug and splice the wires. Is this type of unit more reliable? I was hesitant to get this kind because it looks like the only way to get the alternator out is to cut the wiring.
I'd like to find a wiring diagram, but this seems to be a cobbled together system. Any suggestions?
TIA,
Eric
TIA,
Eric
