I noticed some dampness in the front passenger floor while cleaning out the Bailey's... I'm starting round 2 of much deserved goodness for her this weekend.
I'll be running a power wire through the firewall soon, so if anyone knows where I should start looking while I'm there, I'll send you some free LED bulbs if that's where I find a leak!
Part of my list is to install the subs & amps from the 85, doing this one so the amp rack can *easily* be removed to swap it out between cars (and to check/change the fuses ) It will incorporate awkwardly-located small padlocks so it will still be a challenge for someone without the key
I also have a set of old school Polk 5 1/4" components that I reeeeally hope still work...!!!
