Ok for several months now ive been having a slight miss every now and again at any constant speed. So last week I found out I had a code for a bad egr solenoid, replaced that and all was perfect for about two days. Now its back its a very slight miss only happens at speeds of 65+ and happens more often with the cruise set although it happens with the cruise off just not as often. If im going under 65 with or without cruise engaged it never happens. Its also not very consistent sometimes itll happen every few seconds, sometimes every two or three miles and sometimes it will only happen once or twice every fifty miles. Im just hoping somebody may have some ideas, ive talked to one mechanic who said it may be a faulty pip sensor but when I mentioned its been doing this for months he said that was highly unlikely it also seems to be getting better as it used to be a sudden jerk and its now so slight you can barely feel it any ideas?
Btw car has new plugs,wires,cap and rotor,tfi module, ignition coil, fuel filter, air cleaner, map sensor, and alternator all within the last 6 months also tps is set to .9 volts. Also code 11 both KOEO and KOER so nothing to go off there.
