My 1989 Grand Marquis GS sedan "Ebyt"
    If you're upgrading to the 2.5 in exhaust, consider a pair of 2.5 in Walker tailpipes (54016, 54017) originally intended for the Impala SS. (do a search here, lots of guys have them)
    Hard to come by nowadays but Rockauto still has them for about $35 apiece, I just picked up a pair and was only charged $13 shipping for both!
      You'll need to add a friction modifier to the great oil too.
      Sent from my VS980 4G using Tapatalk
      Using Tapatalk
        Will those work on a wagon? The only reason I ask is because the tips turn out the side and I have a hole in the bend just behind the axle. Are the hangers oriented right for me?
        Sent from the crapper
          don't remember what type of gear oil... but pure synthetic is best (add friction modifier if not already in the fluid). fluid changes every 30K miles unless you're autocrossing it, then it might need to be more often. rebuilds schedule I go with is when it stops working and acts like an open diff.
            @sxcpotatoes: I won't be slicktopping Ebyt for a while.... probably not this summer. The top's cracking a bit, but it's not terrible. Shame they don't sell the chemicals that work together anymore. I'll be sure to look for the Goo Be Gone stuff when I prepare for the slicktop conversion.
            The Goo Gone nor the Goof Off stuff works anymore, they changed their formulas. Some people say aircraft/aluminum paint stripper, or just a heat gun (but none of those work well). Expect to spend 10-30 hours or better trying to get that glue off AFTER removing the cracked vinyl top.
              doesn't 3M make an adhesive stripper that works? I remember someone mentioning it... possibly Dave about the brown blob.
                They will, you'd just need to put 90's on them.
                There are no hangers, it's a build-it-yourself exhaust system.
                  @Louis: I was looking for the Impala SS style tailpipes on Rockauto yesterday.... with the part #s you mentioned. I found these:
                  http://www.rockauto.com/catalog/moreinfo.php?pk=137875
                  http://www.rockauto.com/catalog/moreinfo.php?pk=137876
                  Price matches what you said. But they don't look anything like the setup on Zack's HPP Box. Is it just the angle of the picture?
                  @kodiak: That just jogged my memory.... knew the expression "friction modifier" was familiar. And then it came back: Diff fluid is different from other fluids.... you need to add friction modifiers to it. Diff fluid is also very viscous IIRC, similar to molasses.
                  @sly: I've heard really good things about pure synthetic for motor oil. I'm not at all surprised to hear pure synthetic diff fluid is good too. I'll see if I can find some with the friction modifier next time I go on an AutoZone safari (perhaps as early as this weekend).
                  @sxcpotatoes: Dang. Guess I'll just look around local AutoZones (hopefully soon) to see if I can find some aforementioned 3M adhesive remover. I'll definitely need it later.
                  Bought some 3M double-sided badge tape from a local AutoZone. Now just to find & re-affix the badges!
                    Rear End Friction Modifier is available from your local Ford dealer or for better pricing, from EBAY. Get the Ford stuff...
                      Also check out www.bobistheoilguy.com their Motor Oil University articles are interesting.
                      Sent from my '85 Lincolin Town Car
                      Using Tapatalk
                        @miamibob: Oh sweet! Didn't even know you could stuff like that on Ebay on the cheap. Will definitely buy the Ford stuff when I do.
                        @kodiak: Indeed. It's interesting when they compared the engines and the wear rates. It gets nerdy quickly, but I can follow it decently well
                        In the meantime, we have updates!
                        -Ebyt's registered, insured, plated, and 100% legit. Winning. Got to drive her around a bit.... and all was right with the world. Until I failed NYS inspection, haha. Dry rotted outer edges of tires will do that- even if said tires have a good amount of tread left. Other marks against her were rusted front brakes, which will be replaced accordingly.
                        -Bought a 130 amp small frame alternator, a set of four 16 inch wheels from a whale P71. Would've also gotten an aero rear end, but the yard I went to (Northside Salvage) didn't have it in stock yet. Because the aero rear end wasn't there, I didn't bother buying rear disc stuff. Ebyt's rear drums are fine as-is anyhow, they passed inspection with flying colors. Front discs did not; they were pretty rusted. They're getting replaced by a reputable shop as we speak. Ignition system will also be inspected, and fixed where necessary, so I won't need to start the car with a screwdriver anymore. Haha. Now just to decide on a set of 255/50/16 tires.
                        Quick question about tires. Can I still rock 255/50/16s even without the aero rear end? Any brake clearance issues n' stuff? I don't have the parts around for rear disc brakes (an aero rear end is a prerequisite, and I don't even have that yet!).
                          They'll fit fine (at least they should).
                          The Walker 54016 and 54017 are what you want.
                          http://www.grandmarq.net/vb/showthre...6-Alternatives
                            @pantera: Gotcha. As much I wanted the 255s, I ended up going with 245/50/16s. Much better prices for those compared to the 255s- some $200 difference! Reputable shop will redo front brakes, fix quirky ingniton, and mount new tires this week. Should be ready for the weekend. Once she's set cosmetically, I'll start ordering parts. The Walker pipes will be among them.
                            Questions on body work below.
                            I plan on fixing the surface rust this week. After reading a Hot Rod painting article, I think I've got a basic idea as to what needs to be done. Please correct me if I'm wrong:
                            PRIOR TO PAINTING:
                            -Mask-tape off any areas you don't want to paint
                            -Don your nitrile gloves and other protective things
                            -Remove surface rust with some sort of abrasive (Sandpaper, sanding board, etc.)
                            PAINTING:
                            -Hook up your spray gun
                            -Apply etching primer
                            -Apply urethane beige paint
                            -Apply accelerator, for quicker drying times
                            I hope that's how it goes in theory. If I understand the theory, I'll eventually understand reality. There are still problems though. Where would I go about finding Ebyt's beige paint, the primer, and the accelerator? What about the tools?
                              If there is rust you can see, there is rust you CAN'T see. Be prepared.
                                A couple of online sources for paint that I know of:
                                http://www.automotivetouchup.com/indexbrightcove.htm
                                http://www.duplicolor.com/
                                I have ordered from automotivetouchup for a couple of small practice spots. My first try kind of turned out terrible, so I'm not really good for answering any questions. Although the fiberglass piece above the pass side tail light that I did actually turned out decent, and the color matches pretty well.
                                I did learn a couple of things in my experimenting though. If you're going to do a small spot you will still need to do the whole panel and prep-work can make or break the paint job just as much as any other part of the procedure.
                                I might try again this summer and hopefully do a better job this time, I'm learning as I go.
