Hi all! I recently bought a used 98 MGM at 78,000 the had the common intake gasket leak. I was told by the owner that the vehicle had been unused for about 3 years since the leak happend. When I bought it I immediately got to work!
Dorman intake, Motorcraft thermostat, radiator hoses, water pump, 4 bad coils, heater return pipe, plugs, egr, idler pulley, belt, battery, oil pressure switch, fuel filter, and other misc things. I got the car running and did several oil changes to clean out the engine. I hade a persistan miss/ knock the I couldn't pinpoint!
I was ready to throw in the towel. I started to thing that maybe it was the cam followers the were possibly gunk-ed up like the oil pressure switch. Started the car and oil flow was good to the timing chain and followers and they seemed fine. Stopped engine and I saw this. Anyone ever seen this? I will consider the whole engine junk at this point as I have no idea what else could be bad internally.
