would a 400 c.u fit my 84 merc?
    Originally posted by Grand_Marquis_GT
    Very tempting...
    Also tempting to just find a 400 block to build with forged slugs, and drop my good cleveland heads on there
    400 with a TKO would ROCK!!:heyhey:
      Tom- you're already doing a 351C, stick to the plan. Let Dave do the 400 and ya'll can duke it out once you're done.
        A 351C will still kick a whole lot of ass :evil:
          351cEFI??? with a TKO anyone thoght about that one.............or 400 EFI with a TKO???........oooooooh A 460 EFI SUPERCHARGED WITH A TKO just evil lol:evil:
            I think you'd need more than even a TKO for that.
            Good luck getting Tom to run anything that requires a computer!!
              Originally posted by Mercracer
              A 400 should bolt into a Panther just fine.
              It is too easy to get 400HP+ from a 400.
              351C 4V heads would be awesome with 400 cubes.
              450HP+ would be easy.
              You can bolt a C6 or a C4 up to a 400 with the correct belhousing.
              hmmm.....I think I might have a new direction for my motor here....
                With a torch, and a sledgehammer, anything will fit.
                  Won't happen.
                    LOL THOSE DARN CARBS AND THOSE SMALL PEACES PLUS YOU HAVE TO ''WORK'' ON IT TO GET IT TO RUN RIGHT...LOL...just messin with ya my capri is carbed lol............................................... .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. ................??? dont you work on computer's?
                      well if i do this it probly won't be till next summer, ill just pull to 400 out of the lincoln and clean it up, so next summer i could just drop it in,,
                        Won't happen.
                        Hi GMGT
                        Your Rover has a computer :p
                        Regards
                        Dereck
                        President and founder of The Turbine Wheel Appreciation Society and Little Debbie Cake Connoissuer
                          There are no AODs that will bolt to the 400M. I looked into that a while ago. Nothing fits. Only the C6 and FMXs will bolt up.
                          2000 Grand Marquis LS
                          Mercury Owners Group member
                            If the 400 has a 460 bellhousing pattern then he can use the F350 AOD (not sure which it was)- it was a 460/AOD (I think E4OD) combo, if I remember correctly.
                              Pretty sure it was different. I looked hard, but that was 5+ years ago, maybe someone figured it out
                                Maybe nobody makes anything for the 400M, but you can get an AOD with a 400 Ford bellhousing (same as 429/460) pattern from several of the trans shops.
