Pulled my codes.
    I asked about that hose before and no one knew what i was talking about ), should i plug it or... Should i take the one thats near it, ( It was burnt at the end before i bought it. ) and splice it together?
    Thnaks mang :-D
      Find out where exactly those hoses go before you splice things together. The EGR connection should be a green line if I'm not mistaken. I don't know if the EGR solenoid is on the passenger fender or on the valve cover for a CFI car though.
        at the very least plug the vaccum hose, but you need to plug it from EVR solenoid which is the supply to the EGR.
          I still dont know if i have a spacer or not :-/, nor if that bolt( In the first pic), and it's twin are the one's i take loose. Any help on this would be aprechated,
          Thanks mang's :-D
          Dark
            Holly shit Im glad I don't have cfi, should stand for "completly fucked injection"
            Throw a 2bbl on that bad boy and be done with it!
              I see you havent studied my diagram enough yet!
              It shows you exactly what hose is supposed to run the EGR.
              There is one line that runs under the car, its the one going between the fuel tank and the charcoal canister. If its rubber hose is leaking it will make a gas smell. The canister purge is done with a vacuum operated inline vlave that is activated by one of the vacuum solenoids on the valve cover (on CFI)
              oh and yes youves got the spacer... the EGR comes off with those two nuts on the back of the spacer - one is 1/2 other is 9/16 - EGR should slip right out. get a new gasket if the old one is torn up!
                ^_^ Woot, ill try that :-D I gotta get some open end wrenches badley :-/ socket's wont fit back there....
                Thanks Mang :-D
                  :-D well i got my egr off yesterday and cleaned it with a toothbrush and gas :-D, i must say it was preety nasty looking though... Umm hat to ask but where was the o ring supposed to be?
                  Thanks mang's
                    why bother cleaning the EGR? you dont have the vaccum hose hooked up to make it work.
                      ^_^ That might explane it to.... Humm if only i knew more about this demn thing.. Thanks for the insight though 88 :-D
                      Dark.
                      : Edit : O yea is that the black line comeing out of it? or is there another im unaware of?
