Yes it is. Like I said my alignment guy is good. He is also a panther enthusiast. He's the one with the painted and modded colony park that was for sale for awhile.
help on changing intake gaskets
Sport trac wheels > Explorer wheelsOriginally posted by mrltdThat's an old pic, he has sport trac wheels on it now.http://secondhandracing.com/Home.aspx
putting this thread back on track, I pulled my lower intake without moving the distributor. Also +234234234 on the make sure the end seals are good and tight, I had to re-do mine 3 times!! the 2nd time was for not having a big enough RTV bead, its gotta be BIG, but in the end I used rubber felpro gaskets, hasn't leaked yet.1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
takes 2 min to yank the distributor, makes the job much easier
do you need to put rtv on top of the rear and front gaskets?
I just got my gaskets from summit I got the fel-pro ms9334 intake gasket set and the ford racing valve covergaskets part # FMS-M-6584-A50
One more thing what size vaccum hoses do I need for the upper when I change them? thanks mangs
:offtopic:
