what is a good header gasket?? I'm putting on the stock mustang shorties over my flowtech unequal lengths because they are rusting out and have leaks in the collectors. Also do those locking header bolts by "Stage 8" really work?
whats a good header gasket?
if you're using the stock HO shorties, regular old manifold gaskets from Fel Pro are fine. Don't need special bolts either, just use standard bolts and lock washers.
If you're using aftermarkets, I've had good luck with my MrGasket ones. Not the stupid copper things, these are a black color gasket.86 Lincoln Town Car (Galactica).
The Mr Gasket "ultra-seal" line are the black ones. Ive used them many times with good luck. I'm using a fel-pro gasket on my 408 only because the Mr Gasket gaskets are a little small for the exhaust port dimensions
'80 Town Coupé
i have some Mr gasket ones, but they are white and have writing on them. I don't think they are the top of the line ones.1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
Mr Gasket Ultra-Seal for the win. Only header gaskets that actually sealed for me.
The key is to install everything, torque 'em down, then let the engine IDLE up to temperature... then let it cool down ENTIRELY and torque 'em again. You'd be surprised how much more you can turn the bolts after they've heated up and cooled down. Do it once and you should be good.
I just took a stock bolt and went to the hardware store and picked up some grade 8 allen head bolts. They worked really well. I want to say they're 3/8-16, but don't hold me to that.2011 Mustang GT Premium, MT82, Kona/Saddle, HIDs, 3.73s, 19s, hood/side stripes, UPR 1.5" springs with adjustable panhard bar, and UMI solid LCAs and relocation brackets.
Originally posted by FreshmeatMr Gasket Ultra-Seal for the win. Only header gaskets that actually sealed for me.
Im using the Percy's Dead soft aluminum gaskets, work good, but are a bitch to install with my headers. Also cost $35 for the pair.http://secondhandracing.com/Home.aspx
If the mounting surfaces are still nice on the heads and stock HO headers then you tecnically don't need to run gaskets since they originally didn't come with gaskets.1990 Country Squire - under restoration
the factory doesnt use gaskets on iron manifolds or on the stock shorty headers. Use a wire wheel on a drill or some sort of abrasive pad on a dril and clean the junk off both the head and header sealing surface, then bolt them up..... no gasket required.2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011
Originally posted by 89LincolnTWNcarmy flowtech unequal lengths because they are rusting out and have leaks in the collectors
So, do I correctly interpret that you think that Flowtech's are CRAP?
Anybody else have bad experiences with Flowtech's? I'm wondering if they are consistently poor, or you just got a bad set . . . ?
HO with Explorer Cam, Electric Fan, Cop Sway Bars, Dual exhaust with no mufflers, 15x7" American Racing; 215/70R15's front, 255/60R15's rear, 3.55's with Trak-Lok.
well I got mine used off ebay, but still I don't see why they should have a hole in the collector at all.1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
They are the cheapest shorty headers you can get, and you get what you pay for. Now that I've seen a few sets installed, if I was to buy a new set of headers, they would be BBK. They angled the exhaust tubes in such a way that you can actually get a socket with a flex joint on almost all of the bolts. Probably almost 1/2 of the bolts on my Hedmans require a wrench. It might not seem like a huge point, but after you put in 16 of those tiny little bolts, you'll see why that becomes a selling point.86 Lincoln Town Car (Galactica).
yes very true. Putting on those flowtech headers was a major pain in the ass!! It took me 5 hours to swap them out for the stock shorties!1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
Originally posted by 89LincolnTWNcarI'm putting on the stock mustang shorties over my flowtech unequal lengths because they are rusting out and have leaks in the collectors.
Do you expect to see any flow differences between the stock Mustang shorties and the Flowtech's?Last edited by 89GrandMarquis; 12-14-2006, 09:19 AM.
