Speed limiter?
    Speed limiter?
    What's the speed limit of these babies? I posted it in this forum because I heard from someone that it was 5.0 specific. My car is an 88 Grand Marq. I got the needle in the center of the odometer when it started cutting out.
    1988 Mercury Grand Marquis
    Brakestand machine.
    Stock and until you have about 400HP and improved aerodynamics, about 115.
      heh heh
      Brakestand machine.
        That's around where S.U. topped out at with the 3.55's and H.O. 5.0.
          I've had mine there before and it didn't cut out.
          '95 Ford Bronco XL -
          sigpic :rebel:
            YOUZ GUYS DRIVE TOO FAST!
              My CV one just bounces around off the trip reset button, the faster you go, the faster it bounces off. I've only did it a few times at about 3 in the morning.
                Nice pic with the speedo slammed lol.
                  Fastest ive had the 85 is about 105 or so. The 97 ive had on the limiter at 134 indicated about 131~132 actual.
                  (all on a closed course)
                    I had someone following me in a older benz before and everyone in the car claimed I was doing about 125 and still pulling away from them. I don't believe it though. Maybe 110-115. It was slightly downhill with a full HO and 3.08 gears.
                    -Matt
                      It took quite a while but supposedly i hit 125 in bbub, right along side a 2000 civic si. i had no clue but that is what he told me.
                        Those older Benz's run liked raped apes if your ridin' the right on. I drove a '72 280SE 4.5. Fuel Injected, overhead cam V8, factory cassette (not 8-trac, cassette, and they are rare), sunroof, leather, bucket seats, floor shift, 4-wheel disc brakes. Mmmm I almost got addicted to it. And Bank Vaught Doors, too. The speedo went to 160mph, and I'm sure it'd do at least 130 of that. It had marks on the speedo factory telling you the fastest you could go in the first two gears. First was at like 60, second was 90ish I think.
                          I had the old Versailles speedo (which is similar to the marquis speedo) wound back around to 40...Was hanging with a Formula 350 T/A and a FD RX7.... I slowed down when I realized how fast i was going...
                            No, this was a ratty 80's diesel benz, but it did leave quite a trail of smoke for cover lol.
                            -Matt
                              I've been to 115, and had plenty left in her :evil:
