I wonder how spendy it would be to go to a harley custom chopper shop and have custom pipes done up for that car? probably be an arm and a leg.....and whatever is in the bank account.....lol
460 in a Vic?
listen to ed
Concerning Scott's suggestion about the 31-spline limo rear end: It all depends on what tires Tom uses on the car. A few suggestions:
1. Aluminum diff cover, from T/A or Ford Motorsport. The ring gear caps are bad about breaking on the 8.8. I have broken several myself. This is a good patch.
2. Powertrax or Detroit locker variant. Makes the car behave weird on acceleration, but nothing else will do that well here.
3. Aftermarket axles.
4. Axle housing braces. This runs from the ends of the axle tubes, to the front of the pinion snout. They make them for Mustang rear ends, but the GM will need to be custom-fabbed. This keeps the axles housing ends from trying to bend forward.
5. Weld the housing tubes securely to the center section. There are only two pins, top and bottom, that hold the axle tube in place on an 8.5/8.8.
Provided you get good aftermarket gears, the 8.8 should hold up now, unless you are going to try to launch hard with slicks on a prepped surface.
Concerning headers: Shorties for a 514/521? At least a 2" long tube, a stepped 2" into 2 1/16" would be ideal, most aftermarket shorty 460 tubes are 1 7/8", a bit small for a stroker 460, even a bit small for a regular 460 (unless it is a torque/towing motor). If you are going to spend the money on a stroker kit, then don't skimp on headers.
Give me long tubes, or give me death!
Originally posted by packman View PostI like that idea!!! Though it depends on where you live; I know here in NJ, that swap wouldn't work because a carb'd 351 Cleveland never came in a CV. They would consider it an illegal modification. Though there might be some shops out there that still give out passing inspection stickers for a fee.
PackmanLast edited by gadget73; 10-13-2007, 12:31 AM.86 Lincoln Town Car (Galactica).
