Ok this is probally a NOOB (?) but I have a oil leak at the top rear of the motor. I replaced both valve cover gaskets figuring that was it but no. So I took to a shop they said it could be the upper intake gasket. It's leakking about a Qt. a week. My (?) is there a oil line somewhere near that area? Just seem like alot of oil leak to be a gasket!! Thanks for any help @ all...Don
Oil leak
Oil leak
91 w/ 5.0 with eibach springs for a SS Impala ,hd police shocks on front w/big brake uprade,rear shocks for F-150 HD. Dual s w/ glass packs, 15X8 A/R Wheels 5% Tint on rear.http://www.supermotors.org/vehicles/...l.php?id=11699sigpicTags: None
I would say most likley it is the rear intake gasket it can leak pretty bad I think gadget's old motor leaked from the rear intake
-gabe
yes it can pour out fast from there...
get the nice felpro blue rubber replacement gaskets, they have a fat lip to keep them in place while you install the manifoldPete ::::>>> resident LED addict and CFI defector LED bulb replacements
quart every 400 miles mine would dump out of the back of the intake. Makes a hell of a mess. Its the cork "china wall" gasket that fails and pushes out, and you end up with a gap between the intake and the engine block. The oil just pours out of the gap. Its sort of a messy job to replace it, but its not exactly hard. The only thing thats an absolute must, if you do this the oil must be changed after re-assembly and before starting the motor. It will dump some coolant into the motor, and coolant is very bad for bearings to run on.86 Lincoln Town Car (Galactica).
Thanks to all for the help. I guess the guys at the shop was not tryyng to pull the wool on me so to speak..Thanks gadget for the info on the tear down..I will change the oil & filter. I should of done it when I replace the valve covers. OH WELL (WTF)
thanks again.....Don91 w/ 5.0 with eibach springs for a SS Impala ,hd police shocks on front w/big brake uprade,rear shocks for F-150 HD. Dual s w/ glass packs, 15X8 A/R Wheels 5% Tint on rear.http://www.supermotors.org/vehicles/...l.php?id=11699sigpic
As long as you don't get any chunks in from changing the valve covers, its not impending doom or anything, though its not a bad idea. A load of coolant in the oil is a death pill for bearings though. I did it to my car, was in a hurry and didn't change the oil. 50 miles later, zero oil pressure and it had a rod knock.86 Lincoln Town Car (Galactica).
That's something I will try not to do.Sometimes a small shop vac comes in handy to get rid of any lose chucks.Thanks again....Don91 w/ 5.0 with eibach springs for a SS Impala ,hd police shocks on front w/big brake uprade,rear shocks for F-150 HD. Dual s w/ glass packs, 15X8 A/R Wheels 5% Tint on rear.http://www.supermotors.org/vehicles/...l.php?id=11699sigpic
20 year old cork gaskets.... they all go bad after a while. Just gotta change them as they fail. Its what we get in lieu of car payments; repair costs.86 Lincoln Town Car (Galactica).
My rear lower intake seal crapped out as well. Apparently, the cork peice slid out when they were assembling it new. The gasket was still there in one peice, but part of it was pushed out, and wasn't crushed at all. It was actually blowing out the back, all over the firewall and onto the top of the tranny. I lost one and a half quarts of oil over about 150 miles. It has me fooled into thinking it was a tranny leak for a while.
I was careful and didn't get any coolant or fuel into the engine. I also laid three layers of clean rags in the lifter valley when I was scraping gaskets, lifting each out after I finished. Then I vacuumed the lifter valley.
When removing the old gaskets, make sure you get all the old ones off. First, you can use a gasket scraper, or knife. Then, I took a drill with a wire brush on the end and polished up the mating surafaces of the heads and lower intake. After that, I took a razor blade to what little was left.
It is also a good idea to put a very thin coat of RTV around the coolant passages, especially if the surface is pitted.
And I'll agree, the Fel-Pro gaskets with their lips prevent the front and rear gaskets from sliding around. They make it so much easier than gluing the stupid cork things. Plus, they are rubber and not cork.1990 Country Squire - under restoration
Originally posted by Tiggie View PostMy rear lower intake seal crapped out as well. Apparently, the cork peice slid out when they were assembling it new. The gasket was still there in one peice, but part of it was pushed out, and wasn't crushed at all. It was actually blowing out the back, all over the firewall and onto the top of the tranny. I lost one and a half quarts of oil over about 150 miles. It has me fooled into thinking it was a tranny leak for a while.
I've also used the rubber FelPro ones with good luck. Those cork things suck. If you buy a reman Jasper longblock, you get the intake gaskets and a tube of RTV to use on the ends. They quit bothering with the stupid cork things.
Also, a little tip for easier re-assembly, find yourself some longish 5/16" bolts and cut the heads off. These need to be long enough to stick up past the lower intake by an inch or so. Thread them into the heads, set the gaskets in place, and use the bolts as guide pins to set the lower intake in place without moving anything.86 Lincoln Town Car (Galactica).
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Yeah, I've never really understood the cork end gaskets...I can't ever make 'em fit! Certainly on an LA 318 where the intake bolts go in at an angle they're totally useless because you can't get the intake down low enough to make the bolt holes line up.
Interesting that there is a rubber gasket for those, though. I'll have to try to find those when I do my 4 bbl swap next spring. When I put it back together this time I just used RTV alone, which has worked fine in the past, but this time I guess I didn't get quite enough at the front, and it leaks out of there. Oil consumption has gone up a fair amount and of course it's making a fine mess of my freshly painted parts.
