Okay Dokie
    COOL
    Welp, i got the timing cover bolts in now! all of them hehehe.
    Question.
    How do i take the old thermometer out? My book is being dumb on me but not saying..
    Im thinking I need to prise it out. but im not 100 sure of that. ive got 30 min's of day light left hehehehe
      must've had a dirty greasy engine mang. I didn't have that problem
      WELL! Aren't you special! :p
        Welp, got the old thermostat off and new one on, Really wasn't all to hard to do either!
        For further note next person that has to take one off, might i suggest a long 2x2 and a hammer? thats what i used to the T. I tried prising it off and yoinking it off.Nether of the two worked all to well. Actually busted my arm up pretty good trying those two ways.
        The long pice of wood and hammer worked really nice though.
        OK! Next up i believe is the new harmonic balancer!
        hehe, now i read the directions just a min ago. And i have a question!
        It states i need a harmonic balancer install tool. Well i didn't know i would need such tool! sooo, Do i really need this tool or can i just put it on? ( this one im not gonna guess at. cause i don't want to spend another 40 - 60 bucks on another balancer.)
        THANKS MANGS!
        ( GAWD i gotta get some more bat's for my cam )
          Shouldn't need any special tools to install the balancer. Removing it, yes, but not to install it. Just put it on in line with the keyway and pull it down with the big center bolt.
            cool, thanks mang. gonna eat and try it
              On more question hehe. My uhh Crank pole thingy...:-??? Uhh it's got a wee bit of rust on it. What would you guys recomend to take it off? Ive got umm. PB Blaster still and i have a little GUNK engine degreaser.. Ive got steel wool And ive got shop rags.
              I myself am thinking PB Blaster and a shop towl would be good. But im open to ideas!
                What's a crank pole?
                  What the balancer goes on :P im not sure of the name of it actualy )
                    should of kept your crank pole lubed up man.
                      It was rusty when i took it off hehehe. However It isnt any longer! That pb blaster reallly is some good shit hehe.
                      Ok, Heres what all i got done today.
                      All timing cover bolts are in! hehe. And nice and Snug!.
                      New thermostat is on And good and tight as well.
                      Harmonic Balancer is on! And is good and tight.
                      Pully that goes to harmonic balancer is also on
                        the crankshaft snout. Clean it up with the steel wool, spray some pb blaster on it, and install the balancer. Make sure you have at least 1/2" or more of the bolt threaded in before it starts pulling the balancer on. If its not on far enough, smack it a couple times with a rubber mallet to push the balancer on. Don't want to strip the threads out of the crankshaft from not having enough threads in.
                          Thats it hehe, Crank Snout! not sure why i coldent think of it. Aye PB Blaster worked wounders on it heheheh.
                          Quick question.
                          Would you guys use the fel pro gasket that came in the gasket kit? Or would you just use the one that came with the water pump?
                          Im taking a lunch break atm hehe. Ima try to find my wire wheel And maybey even try to clean them bolt's while im on break. And also eat! hehe
                          Thanks mang's.
                          DK
                            Which gasket are you talking about?
                              The water pump gasket
                                Oh, okay. My guess is you're safe using either one.
