there's a gasket, but it wouldn't make it leak coolant. It could cause a vacuum leak which might be giving you problems.
shouldn't matter if the car was made in US or Canada, the parts are the same.
Check something for me. When you set your timing with the spout unplugged, see if the mark on the balancer seems to move when you plug it back in. Also, you've got 10 btdc marked on the balancer, right?
the ecm can go bad. its not real common, but it happens. I think Phayzer had one die in his cfi car, and it ran all messed up. Could be related to not being able to get codes, but there are a few things that can cause that. How are you checking codes anyway? Can you get any codes at all?
