wire harness
    wire harness
    can a wiring harness from a '98 Ford Explorer 5.0 302 v8 be used on my 87 country squire
    Depends; what do you want to use it for? Nothing wrong with swapping over the Explorer engine harness, but you'll have to also swap over the distributorless ignition parts, etc.
      sure it can, if you also swap over everything thats plugged into it...
        not easilly......98 exploder is eecV which has sensors in the gas tank and extra evap canisters with sensors and distributorless ign, also the intake points the wrong way, and the accys are different
          Yay for multitudinous unnecessary evacuative emissions sensors!!!
            Can be? yes. Should be? no way. Way too much wiring work to be practical.
              ok thanks
                With all those extra sensors and junk a stand alone like mega squirt or an AEM stand alone would be best.
                R.I.P Linsey Nelson
                Originally posted by MeanVic84
                Chocolate Rain. Some stay dry and others feel the pain.
                  EEC-V uses a 104 pin connector, EEC-IV uses a 60. Not a direct swap.
                  https://www.facebook.com/jason.baker.1614
                  1985 P43 Crown Vic, "Lightning Interceptor". Project is back on!
                  1987 P72 Crown Vic, EFI 351W (not my conversion), rusty and crusty parts car.
                  2006 Ford Fusion, 30MPG, premium sound, daily driver, 200K miles and still going.
                  2011 Ford Fucus, 36MPG, Sync, wifey / baby mobile.
                    That's a lot of wires an injected car runs just fine without!
                      It's quite different, most of the connectors are different and the components are in different locations. More trouble than it's worth, unless you are going OBD-II, which would be pretty cool. Also remember explorers did not use a distributor, so all of that wiring will have to be cut out of the old harness....
                      I've got 2 87-89 vic harnesses and a 96 explorer harness...
                        You're not a fan of the later distributorless ignition system, then?
                          Actually, I am kicking myself now for not going with the later EEC-V OBD-II setup. Would have been much more fun to play with. I'm just stating that the new harness is not an easy swap onto an old EEC-IV computer and sensors.
                            OBD II is a lot more flexible and easy to diagnose than the old EEC IV stuff. Lots of wiring though. Distributorless is nice, should actually be able to get a longer and hotter spark out of it since the coil isn't discharging 4 times a revolution, it only discharges once every turn (waste spark). Lots more time to charge up that way.
                              You know, I never thought of that advantage of distributorless ignition. Makes me more tempted to try it on a future project.
