(Que thunder and lightning, torrential rains, and a stampeding herd of tens of thousands of large hamsters...)"...and God reached down from up high in the Heavens, reaching forth with His Mighty Hand....and helped Nathan with a little wiggle to help align the starter!"
Yep. That did it.
Pretty much!
1985 Lincoln Town Car Signature Series But God demonstrates his own love for us in this: While we were still sinners, Christ died for us. Romans 5:8
I'll have to try taking some pictures one of these days. I have never seen grime nastier than under that car.
Mine puked oil from the rear of the intake from the day it was bought in 1986 till I replaced the seals in 2004. THAT was nasty. When I did the engine swap, my arms were black for a week. Only reason its basically clean underneath now is the fire burned a lot of it off. Thats probably actually why the transmission cooked, there was a lot of fuel under there.
Probably similar to what had happened with this thing. On the original engine, there was goo ALL OVER, including the front of the heads, the rear of the heads, the top of the front cover, all over the block and oilpan ..... the newer engine is much cleaner, but the chassis never really got degreased.
