Okay Dokie Pt II
    Okay Dokie Pt II
    YUP!
    hehe, this chapter will be about my carb swap
    I have what i believe all my pt's ordered except for the inline fuel pump, the cap and button for the dizzy and the adapter for that... Im thinking local parts whore houses for theses items would be best.
    Also. I half to still get a torq wrench. Some of you mangs that stayed tuned for the last okay dokie. would have noted how i put waaaay to much pressures on bolts.
    So be patient. :P I will be thuro with asking question and taking pics and. Asking more questions :P
    D.K.
    Okay
    allrighty well since all of my parts i needed to order should be shiping heres my first question :P Along with a few others.
    Ok. So first off i been wondering where to start. good place to start i should say. I was thinking of actually starting on the cfi and the intake just to get that out of the way, then the dis then the fuel tank and finally the fuel pump.
    Ok, Other thing i been wondering is. What is a fuel Sump? Annnd. How do i make it?
    And the other question is/was how much torq do i need on the intake bolts but i belive thats been answeered for 18 - 23lbs of torq hehe.
      Another question i have is. What do i ask for when i go to get the adapter for the duraspark dizy?
        Thought of another. What all gaskets will i need? hehehe
          ask for a distributor and duraspark for a 78 couger with a 302 ought to do it. you'll want the 2 connector box with a blue grommet around the wires. almost any 302 non-efi application distributor and box will do the job, as long as it is NOT for a 1985 Mustang.
          gaskets would be an intake set for your car. that would give you the manifold to head gasket, distributor O ring, and intake front and end seals. I like the felpro permadry ones, they have a rubber gasket at each end of the intake valley that works nicely.
            I already got the dizy and module coming hehe. Also got the carb intake coming the tv cable and throttle cable.
            Cool Intake set
            Anyone know what adapter i need, or what it's called? for the distrbuter? Makes it so i can run the proper distributer cap.
            Thanks gadget
              Ok, got my adapter ordered, got the cap and rotor And got the fuel pump :P
              The only intake gasket set they had was for a 2bbl So i said ide wait. Humm...
              So that should do me on my small misc parts i thinks. Sept for the gasket hehe.
              Will a 2bbl gasket set work?
              DOU I know what i forgot now. Forgot the tunning kit Ugha, O well i gotta go back up there anyways hehehe
                http://www.phayzer5.net/carbswap.htm Good reading here mangs!
                  Got my throtole cable today. Man that was quick.! And god dang if it isnt pretty!
                  GOnna be sesy under bay when this is all done and over with.
                    Got my Dizy and Module... And i got what i belive to be the correct diagram. But i have one prob. I cant read these things :crys: Could someone please explaine it to me?
                    http://www.billwrigley.com/vintage/308.jpg
                      Howdey again. I was woundering if any of you mangs could tell me how to be sure #1 was tdc and also the best way to turn the engine. I know how to do it now with the timing cover off buuut im not taking the timing cover off this time. :P
                        big ratched and a 15/16" socket on the crank pulley to spin the motor.
                        TDC is fairly easy. pull the #1 spark plug and stick your finger in it. Rotate the engine till you feel it trying to push your finger off with compression. Slowly turn the motor till the 0 mark on the balancer lines up. If you really want to verify it, pull the passenger valve cover and make sure both valves on #1 are shut. If its 360 degrees off, one of the valves should be open.
                          : drool : Now that clicks with my head for some reason Thanks Gadget
                            Thought i would share my last small list. ( Hoping that this is the rest of the stuff i need.. )
                            1 ft of hard brake line 3/8 inch
                            10 fuel line clamps ( Thats the correct wording aye?)
                            4ft of 3/8 inch rubber fuel line
                            1 inline fuel filter
                            intake gasket set ( No Cork!)
                            Gasket scraper
                            valve cover gasket ( Perma dry from napa aye?)
                            Wire... With the wire what gauge of wire do i need to ask for? This is for the fuel pump mostly along with the dizy and module.
                            Getting excited now So close to doing it :P
                            O yes I found my EVTM book thingy..! Or well i confiscated it back! However i still am at wits ends on the diagram for the module and dizzy . If anyone that has done this could make a pics of there wiring they done i would love you so much :P
                              I've only ever used the Ford ones. They are steel with a rubber insert. They are reusable, and you don't have to worry about them collapsing as you tighten them. They also provide excellent leak protection. They should be around $40.
