Okay Dokie Pt II
    You can see what im talking about here http://www.napaonline.com/MasterPage...=Ignition+Coil
    Is there a sp dizy wire i can buy for it?
      Well I wound up finding a Stock Igniton coil at the local parts house!
      But sadly it must not of been the coil
      So i done some pricing today Same exact one as i have 22 bucks at vato zone..
      My middle name is Sucker i guess...
      Fuck Rock Auto.
      Anyways. Ill let you mangs know what what after i get the new module
        The + side of the coil is the one with all the wires on it. - side goes only to the igntion box. + side I think you have the fuel pump and all that hooked to.
          Howdey. Welp. I got my tuning kit Yesterday. However i still dont understand to much on tuning. I scrooled tru the manule last night. Buuut Ack. Ill be the first to admit when something goes over my head.
          anyways. So how do i tell. If my car is running rich, Or lean. And which one is safer to run? And. Since im wanting to start off with playing with mettering rods. What do bigger and smaller metering rods do? Which one makes it leaner and which one makes them. Richer hehe.
          I know I know. More then likely i still half to do some more reading. But if you mang's could just give me some pointers or a gen direction to start in with this. Ill love you long time hehe. :P
          D.K.
            It will run hot if too lean, and if too rich it will wash your cylinders and thin out your oil. No real way to tell with out an Air fuel monitor, but I guess you could drive it for a week and check your plugs. Sorry I know its not much help.
              if it was running rich there would be black smoke out the tailpipe wouldn't it?
                You are correct sir! Thats like, a couple plugs not firing rich tho.
                  I have no black smoke hehe.
                  Read some more in my book. Bigger rods make more restion to fuel. hehe
                    Is it running again? I'd fix that problem before worrying about messing with the tune.
                      OOO, hehe. Got here running just now :P + rep to evreyone that said ignition controle module :P
                        Got another question. What would you mangs do to keep your wire in your spade connectors/connectors intact? ( Keep them from coming out.)
                          Heat shrink tubing.
                            Are you talking about keeping the wire in the connector where you crimped it? Best bet is to use the right size crimper for the gauge of wire you're using, and if necessary, put a little dollop of solder on where you crimped the connector down. Then, put some heat shrink tubing over the whole thing.
                            Also, use the proper gauge connector for the wire you're using.
                              Cool beans. I was actualy thinking about a dab of solder but didnt know if that would hurt it or not. Thanks mang.
                              Ill make a day out of doing that one day.
                                It won't be super strong...as my electronics teacher used to say, "solder is an electrical connection, not a mechanical connection," but it'll help some. The real key is using the appropriate gauge connector for the wire you're using.
