I suspect I have a sticking fuel injector, hoping somebody can confirm. Also, with no way to know which one is sticky should I just buy a set of 8?
Some facts.
First off - I've had a really bad idle which up to this time I've said is likely due to a faulty IAC valve. Idle will drop to about 500 rpm at a light and it'll run really rough for a few mins. If the light is long enough the idle will pop back and forth between a nice smooth idle at 700 rpms or so and a rough idle at 500 rpms that nearly stalls me.
Had the flu last week. Wagon sat exactly 7 days. Started it this morning and it would not remain running. It'd rev up to 2000 rpms and then fall straight to 0 rpms. Again I'd think this could be the IAC sticking closed. After 6 or 7 starts it started to "catch" and eventually i got into work. Now everytime I'm at a red light it idles really rough, like it's not firing on all cylinders.
On the highway on the drive in, it definately wasn't firing on all cylinders. I'd have to depress the pedal to get the sucker into 3rd gear to be able to maintain speed. Now if I floorded it it'd immediately downshift but I'd have 0 power for a good amount of time. Eventually it's like somebody flicked a switch (fuel injector??) and it'd be like a mule kicked the back of the car and it'd take off. Finally, I've had a ghost code for a little while now on the wagon. Engine running lean in a continuous memory code. Never pick it up on the KOER test, but it's always there on the continuous memory. My thought is I probably have a bad injector or two that is causing a lean condition during operation that I haven't really noticed until now.
Also, it SEEMED like the situation improved as i drove it into work and got some miles on it. That could be my imagination though...
Fuel injectors are used items that I purchased from somebody on here I believe. I've already ran a bunch of injector cleaner though them just knowing they were used items. Do I keep down this path or just replace them? Do people agree that this is a fuel issue? Is there a fuel injector cleaner that I can buy that'll do a good job of actually cleaning them?
Thanks,
JD
Some facts.
Thanks,
JD
