92 lx 5.0 in 83 gm water pump question
    i have an 83 grand marquis that i would like to keep the stock acc. such as ps ac alternator ect i am switching to carb what i have is a 92 lx 5.0 ho the front accessory's are all different i realize my stuff bolts on but will my water pump work too or are the water pumps be two different flow direction meaning can i go to autozone and get a 83 gm water pump and put it on the 92 lx engine i know it bolts up but are they flowing the same direction thank you
    The mustang one is different, you want to but your original application pump on there.
      so by what your saying i should be good to go just order a new 83 gm pump to put on the 92 lx engine thank you for your help
        MAke sure you look at the timing covers first. Theres a chance the ports face the opposite way. If thats the case, you also need to swap the timing cover from your original engine.
        Its possible the Mustang one looks like the one at the bottom right. It should look like any of the others as far as the water pump ports go. The fuel pump boss and crank sensor mounts don't matter, unless you've got designs on using a mechanical fuel pump. As long as the timing cover is the right kind on the Mustang motor, just get yourself a water pump for an 83 Grand Marq and carry on.
          well thank you guys very much for the help it should be smooth sailing from here on out i hope I just needed a little extra assurance before i started ordering more parts thank you
            What would the symptoms of a mismatched pump\cover be?
            I have a '91 CP with an '86 LSC engine. It has a GM water pump on
            the LSC timing cover. It has always used some coolant, but I've never
            determined where it goes......
            Thanks.
              it would probably dump a pretty fair amount of coolant. Otherwise, its possible it may run hot but thats really it. My engine came from an 88 Bill Blass, its an HO motor that originally had a reverse water pump, yet the timing cover is an exact match for the original. No idea why but I wasn't upset to find that.
