Hey all! I'm planning on getting a '97 Exploder 302 sometime really soon. And I'd like to assemble the parts associated with the Exploder Swap. I want to go over a checklist of sorts to confirm which parts I will need to get, and which ones to save from my old motor. I want to keep the air conditioning, EGR and emissions stuff (including the smog pump) as well so that's why I picked a '97 Exploder (internal EGR passages).
So far, from my memory I know I need;
From My Old Engine:
The oil pan from a fox body mustang or panther
The timing cover from a fox body mustang or panther
Water pump from a panther
Fuel Rail from a panther
Distributor from a panther
From The Exploder Engine
Modded Exploder Throttle Body with throttle linkage from my '86
GT-40 Intake with internal EGR passages.
Fuel Injectors
Elsewhere
Compatible ECM (HO Speed Density)
Headers or manifolds compatible with the spark plug angle of the GT-40 heads
Lightning EGR Spacer (Looks at Scottmang)
Am I forgetting anything else? I will be rebuilding the exploder motor in school. So I'll have access to a machine shop.
From My Old Engine:
Fuel Injectors
Elsewhere
