well... i suck. i keep changing my mind. now im thinknig after losing a few bids on cobra intakes that topped 300$ u.s.
that i may rather go for a 347 stroker crank. is this a good idea for more tq? would i need to upgrade anything else or would my setup feed it fine.
im supposing id need to return the bearing kit for my polished crank that i had ground 10 under. and i can use my stock rods and stock replacment pistons (the ones i got have valve reliefs now) but going this route seems cheaper than the intake.
http://cgi.ebay.com/ebaymotors/SBF-C...95285008QQrdZ1
would i need a bigger fuel pump and convert to maf?
that i may rather go for a 347 stroker crank. is this a good idea for more tq? would i need to upgrade anything else or would my setup feed it fine.im supposing id need to return the bearing kit for my polished crank that i had ground 10 under. and i can use my stock rods and stock replacment pistons (the ones i got have valve reliefs now) but going this route seems cheaper than the intake.
