Hi, back again.
After fixing stumble problems its still not good.
Problems with my 1985 cfi colony park.
It stalled again. After a half hour drive it sat for 15 minutes. Than after a start i put it in gear and it dies. I could only return home by constantly reving the engine. The engine speed saves me from stranding on the highway. After about 10 minutes it return to normal driving.
I just installed a brand new correct distributor (motorcraft), also a new tfi. Reinstalled the egr, but still with a block off under the cooler. I also installed a brand new motorcraft tps, 0,94 volt closed throttle
I checked alot of connectors, but nothing found. A cleaned the ground of the eec.
I reset the eec and checked for codes afterwards non found. Than i testdrove it for 10 minutes and checked for codes again.
21, 41, 34, 32, 77, 51, 54, 61, 55, 63
The act act egr tps sensors are new. All the contacts are thoughroughly cleaned and inspected.
55???
All the code related sensors use sig rtn from the same pin...?
Any help is appreciated.
Adam
55???
Adam
