i want to get a shift kit to compliment my 3.73 gears and HO conversion (when it gets done)? any recommendations? and how hard is it to put one in?
can i get a shift kit for a towncar?
is this a good one that will fit?
http://cgi.ebay.com/ebaymotors/TRANS...spagenameZWDVW1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
I need to pick one up myself. I already have the HO governor sitting in the trunk where it's been for months now. I'll probably get the cheaper kit, use my HO governor and call it good. I don't really need the pump-shift action of the 2 stage kit or the 5200 rpm governor.86 Lincoln Town Car (Galactica).
