I installed a new oil fill cap because the old one wasn't really closing properly and could open too easily, but now I'm getting a slight l burning smell through the vents and outside of the car. No smoke and the cap looks okay but it's the only thing I've changed in the entire oil system. Went to install an oil pressure sender and adapter but my stupid power steering pump is in the way, so I put the original dummy light switch back in. Gotta buy a little elbow at the hardware store or something to angle it away, but that's beside the point (I think.)
I just got a generic replacement cap. I have absolutely no idea why it would cause me to smell burning. All of my fluids are good. and the cap SEEMS to seal okay. Oil/filter are new and clean and coolant is also brand new. PCV system is about 3-4k old and I don't see oil leaking anywhere - I assumed at first that some spilled on a manifold during the change and passed it off as nothing - but it's a day later and the smell is still there.
I replaced the radiator, hoses (upper/lower/bypass hose), thermostat and gasket, and water pump/gasket in the past few days - As well as the previously mentioned oil fill cap on the valve cover -Could any of those smell funky for the first few kilometers after installation? All of the parts were new except the reman Ford water pump.
