1985 Grand Marquis Ignition spout location? where is it?
    I just got my 1985 grand marquis and i want to advance the timing and make sure timing is correct anyway, because the privous owner said he set it and i dont trust him. My marquis has 38,000 miles and still had all of its ignition wires, plugs, cap and rotor so i replaced everything with Ford Racing red wires, msd cap and rotor, and motor craft plugs. Im ready to advance timing but i cant find the darn spout. On my mustang and truck with 5.0's its right by the tfi module. Where is it on the marquis? and what do you guys bump your timing to? im thinking 14? to run on 87 octain fuel Thanks !
    1985 Crown Victoria Tudor
    1990 Mustang LX 5.0 conv
    1996 F250 Power Stroke
    2004 Mustang GT conv
    round plug right near the distributor in the harness of wires that come from the distributor plug.
    CFI cars don't usually want more than stock 10btdc timing. They already run lean under heavy throttle, more timing just makes them more inclined to ping. You can try a little more but I wouldn't be surprised if its not happy about it.
      ok ill double check it, maybe give it a little more. Me and my friend searched for an hour to try and find that spout.
        Mine would ping at 8 degrees with premium, lol
          here's some pic's its the black plastic piece Click image for larger version
ID:	1268069Click image for larger version
ID:	1268070Click image for larger version
ID:	1268071Click image for larger version
          don't advance timing engine does not like i set mine just under 10
          runs good no ping i use 87
          WARNING: Above advise is based on actual experience or just plain common sense. In the event said advise is determined to be incorrect you are entitled to a full refund of exactly what you paid for it.lol
          85 LTD Crown Vic Coupe 302 CFI Dual Exhaust No Cats Thrush Welds
          pwr windows, locks, seat, antenna
          cruise, tilt, white on white, maroon interior
            ok... on that car... that is the spout. looks like that one has a different harness on it from the usual suspects.
            just disconnect that connector. It'll work the same as removing the jumper block from the typical harness on all the others I've seen.
              84-85 use that style. 86+ use the square plug that everyone is familiar with.
                Ok thanks guys. I can't believe I missed it. And i had a 85 crown Vic. I'm gonna time it soon, so I hope it will pick up a little pep.
