Can tapping on it revive a dying coil, like a dying electric motor?
    I wouldn't think so, but this happened tonight. Of course I know just because you do 'something' and a problem goes away, it doesn't necessarily mean it fixed it.
    So tonight, on a 'date' no less (how embarrassing), the 85 doesn't want to start after getting some fine Mexican food.
    No spark... the EEC relay was clicking on, but pulling the coil wire off with enough room to arc produced nothing. While cursing that fancy looking mystery coil I installed, I fished around in the trunk for the old OE one, and didn't find it. So I gave the fancy one a couple love taps and she started right up.
    In case of coincidence, I'll also be carrying a couple used TFI modules and the module tool in that car, along with the old coil.
    If its not either of those its got to be the PIP sensor in the distributor right?
    I think the 85 is mad at me, for having to think twice before taking her out for the date.
    I can't answer your question, but that ending quote from "The Red and Green Show" comes to mind reading this.
      It's possible...if one of the windings in the coil came/broke loose and it fell back into place from tapping it...but i wouldn't think that fix would last long, especially with engine vibrations. just a thought
      -Phil
        Or maybe the connector had a shit connection until you screwed with it?
        1992 CVLX. 5.0 HO/GT40P/T5/3.73/trak-lok with bolt ons. 02 front CVPI setup, rear HPP setup, CVPI shocks around, F250 radiator, e-fans, and the power of 3G. 15.92@89mph, 2.4 60', 4700' elevation (5500' DA) with 3.08 open rear and the old oil chugging 289. RIP.
          Maybe he's secretly:
          Pete
            The connector is practically brand new, I gave it a good wiggle with no results. gggrrrr
              I wouldn't play with it and wait to get stuck again. New OEM Coil and if needed TFI and be done with it. At least you didn't have to tell your date you ran out of gas.....Bobby
                more likely something flaky with the plug I'd think. Coils will sometimes come back to life if you ice them but I've never heard of tapping one to make it go again.
                  If it's got a short, hitting it might move the wires apart so they aren't shorted, but it won't last long.
