My 88 mgm
    Darn you Texas dudes and the rust free undercarriages.
      Lol and to me I fell like it’s rusting a lot. 😂
        Originally posted by Elias View Post
        Lol and to me I fell like it’s rusting a lot. ��
        Nah... your frame is nice... the body on the other hand...
          Just surface rust sly hopefully next year I will be painted with a new top
            LOL, I know you've seen pictures of my cars. Especially The Ice Car, and the picture you saw on FB was the good side.
              The Megamerc has a super solid frame, but the body is deteriorating.
                The new wheels look mean. I love the dish on them.
                  Thanks
                    Elias,
                    Have you put many miles on the new wheel/tire combo?
                    Any rubbing or cutting issues?
                    Recap, You are running
                    295/40/18 Nitto 555 G2s
                    1.25" spacer
                    6.28 BS
                    __________________________________________________ ________________________
                    I already have
                    1.5" spacers
                    The wheels I am looking at are
                    10" 6.3" BS
                    Same tires.
                    What think Ye?
                      Elias,
                      1.25" spacer
                      6.28 BS
                      ____
                      I already have
                      1.5" spacers
                      10" 6.3" BS
                      Same tires.
                      What think Ye?
                      Sorry been busy
                      I’ve put about 50 miles on them
                      Tire size is nitto g2
                      295/40/18 rear with 1.25” spacer
                      255/45/18 front with 1” spacer
                      It does rub the inner fender on the driver side a bit on certain bumps on high speed but it’s probably because I still haven’t put all the bolts back on when I replace it with the 91 inner fender. Right now i haven’t really had time to work on it as much it’s currently sitting on jack stands from the rear. Been working to much with my new job. And been messing with my new to me 04 marauder. But Thursday I get out early so should finish and grease the rear arms.
                        Maurauder, cool! I've wanted one since they came out.
                          I haven’t done anything major to my 88 mgm but I received my lower guage pod that I will be using. This it the one I am going to be using. Not finished I will be painting it same color as my a pillar pod. And here’s a few pic
                          https://paceperformance.com/i-609441...pod-15022.html
                          Edit on first and second pic which do y’all think will would look better guages push towards the back or towards the front and closer to the ash try. Also it will need trimming if installed closer.
                            Here’s how it would look at night
                              Look like the two would be more visible the closer you set the gauge pod towards the front.
                              nice piece. Will look nice and finished.
                              Way back when..... I used to run three gauges down there with the individual pods mounted to the ash try. The weight of the gauges over bumps would cause the ash try to fly open. Just stared using door panel christmas trees wedged in the back hinge to prevent that from happening.
                              Pic from 10 years ago.....
                                Aestheticaly, I like the 1st pic better but visibility while driving is key.
