cone air filter?
    Factory carb air cleaners are usually a cold air intake actually, but everyone rips those and the ductwork out. Cold air is denser, so it makes more power.
      I hear if you use hot air intake, you get better gas mileage?????????
        I don't even know the size of mine. My dad found it at the junk yard he works at. I just threw it on like so.
        1989 LTD Crown Victoria LX.
        -3.73s' w/ Track Loc - KYB GR-2 Shocks All Around - TRW HD Cargo Coils Rear - Moog Front Coils - 1 Inch Rear Sway Bar - 4.6 Lower Air Box- Stock Headers - Off Road H Pipe - Turbo Mufflers.
        4 Door Muscle
        Supermotors
          Blackhawk, the way you have the pipe right now you're actually choking your engine as the air has to make a very tight turn to enter the manifold through that rubber elbow. What I'd do if that was my car is totally ditch that elbow, go buy a straight silicone connector from the local AutoZone (the blue sleeve in NA's pic, comes with the two clamps too), and flip the metal pipe the other way - the end where the filter is now would attach to the manifold through the silicone connector, and the filter would go to the end where currently resides the rubber elbow. That'll give you a pretty smooth flowing intake, I think.
            Sounds like a plan.
            4 Door Muscle
            Supermotors
              Dumb Question =
              Could the bad intake set up have anyting to do with none de-reving exahust noist. When I rev it up it dos' thave a nice tight sound coming back down. It kinda dosn't do anything. Is that just because I have 2 1/2 inch pipes on a lopo?
              4 Door Muscle
              Supermotors
                Dunno, I just took all the exhaust off my car (redoing the part behind the H-pipe), and now when I floor it from idle it sounds as if something's about to blow up (nice little explosions), when I slowly increase the RPMs and then just take my foot off the gas it winds down pretty fast, but again making "explosions" every now and that. With the pipes connected de-revving it sounded just fine, and I have only glasspacks so no really any flow restrictions. Your 2.5" pipes do make for lower speed of the gases inside, but you should still be able to hear the RPM drop I think.
                  You have to fix your inlet tube, you're choking the motor. Look at my underhood pic.
                  '90 Mercury Grand Marquis GS
                  5.4L swap coming soon.
                    Yea. I'm going to go ahead and get a differnt connection at the store when I go and pick up my frotn coil springs insolators.
                    4 Door Muscle
                    Supermotors
                      got the new boot.
                      4 Door Muscle
                      Supermotors
                        Any pics?
                          Will tomorrow. The intake is sits down more into the engine bay now. Like next to the alternator down the front. Looks good. I want to get pcics of my suspension tomorrow too. It's the last day I can cause they will be in the car after tomorrow.
                          4 Door Muscle
                          Supermotors
