GMGT's new powerplant
    i picked up toms 351c 4v today......just got back........it's a 4bbl cleveland out of a 1970 torino........heres a few pics
    scott
    Thing looks pretty big... how do you plan to mount it in there?
      the mount holes and spacing are the same as a smallblock.......exhaust and engine bracketry are 2 challenges that come to mind, but i know it will drop right in
        Wow man next project the genius at work once again
        The Best
          Kick ass Scott! That should be a pretty stout block, being from 1970. Im diggin the air cleaner.
            Thats going to be quite an upgrade for ol' GMGT since I last saw it. does that engine run now? or are you going to tear it down and rebuild it? how much power you think its making?
              Is that a spreadbore carb or a standard looking carb?
                You SOB. I want the heads. If you find a pair let me know.
                1989 Grand Marquis LS
                  Wooo can't wait to hear that fucker run. GMGT's gunna be kickin ass n takin names.
                  Nick
                  88 Colony Park LS
                    It's finally arrived!!!!
                    Thanx mang, I'm gona use that aircleaner as decoration!
                        not the spreadbore carb but the intake looks spreadbore
                          I am sure that smallblock C6 will come in handy for another project down the line :evil:
                            You Lucky Bastard! I've been searching for about 3yrs for a 351 cleveland in decent shape to rebuild and drop in my box.I ended up giving up the search 2 months ago,and settled for a '96 Explorer engine with 65,000mi which came out of a totalled explorer.In the yards around here any good engine gets snatched up fast by someone.Enjoy that thing,it's gonna be a beast in the marq.
                              Does the 4 cast on the inside corner of the heads have a big dot cast next to it?
                              What is the year and engine code from the metal engine ID tag? Not the CI, but the engine code. It will start with 3 numbers and may have a letter(s) after them.
