I know one of those bolts is a bitch to get at, on the SEFI cars. What kinda tool do I need to make life easier?
Thermostat housing
ratcheting wrench yoPete ::::>>> resident LED addict and CFI defector LED bulb replacements
Ratcheting wrench worked...to get it loose and to tighten it, yay 18 bucks for a wrench I barely used.
BUT, the thermostat is replaced and it's still overheating.What's next? Radiator? Waterpump?
'95 Ford Bronco XL -
sigpic :rebel:
How fast does it overheat? Could be plugged radiator and/or bad fan clutch. The water pumps usually don't fail internally, mostly its just the seal or the bearing that goes out. Usually they keep on pumping even while puking water like mad.86 Lincoln Town Car (Galactica).
It took awhile. I drove it around for a little before I saw it puking again. I'm gonna get a new cap, see if that helps. Then I'll go for a radiator.
Also, yea the fan clutch is bad. It's been like that since I got the car how many years ago. It's on the list lolLast edited by boXman; 07-25-2006, 10:15 PM.'89 Ford LTD Crown Vic - '92 Ford F-150 Custom -
sigpic :rebel:
i wish that they didnt have plaxstic ends or i would solder mine so=ince it is leaking from the radiator on the passenger top side. i need to flush the system and put a different radiator in Baby. i just helped a panther owner on the road out yesterday, monday. they had a blown radiator hose and they were surprised i had one. i told them i stock up parts to fix my big ford. thatey had a 1989 TC.
my radiator has metal tanks woohooPete ::::>>> resident LED addict and CFI defector LED bulb replacements
