My car ran three seconds faster in the 1/4 after I installed one. I say go for it.
HO Mustang Intake Plenum Spacer...Worth it?
Are you being sarcastic or serious?~David~
Originally posted by 87gtVIC View PostAre you being sarcastic or serious?
I'd buy 10 of them and some long ass bolts and have the intake stick out through the hood.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
Even though there is nothing really to gain, I will still go ahead and purchase one when some pay checks roll in. Really want to paint up the mustang valve covers I have as well as the spare Mustang upper intake I have....installing this then will be worth the removal of the other pieces.~David~
wish i had a couple spare paychecks
Originally posted by pantera77 View PostIt's Pirate. You should know the answer already.
Ram intake stacks for teh win!
I just purchased a 1/2 Ford Racing phenolic intake spacer...problem is no hardware comes with it. Will explorer hardware work with a 1/2 spacer on stock Mustang intake components?~David~
how much did it run you Dave?sigpic
I bought it used from another forum. spacer and gaskets for 35 shipped. I just have to figure out a mounting solution that will fit underneath the plenum plaque.~David~
just need to use longer bolts. I think they're 5/16, nothing overly special about them. Short bolts you'll find at the hardware store easily, the long bolts you may have to request from the store or something.86 Lincoln Town Car (Galactica).
That is the conversation I had with the seller. The shorter ones should be no problem to get, but the two long center ones may give me a pain in the butt.~David~
I had no luck finding the right long bolts, i went to large and small hardware stores, and even a place that sells nothing but fasteners/fittings. It seemed every place went from 6" (too short) to 8" (too long)
Luckily after C4C there were plenty of 5.0 explorers to nab bolts from (they worked) I think I have a couple extra if you wind up needing them.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
Originally posted by 85crownHPP View PostI had no luck finding the right long bolts, i went to large and small hardware stores, and even a place that sells nothing but fasteners/fittings. It seemed every place went from 6" (too short) to 8" (too long)
Luckily after C4C there were plenty of 5.0 explorers to nab bolts from (they worked) I think I have a couple extra if you wind up needing them.~David~
hhmmm... I never measured it. lemme find a pic... looks like about 1/2 inch...???
