i have a question.... if i have 15 by 7 inch wheels, can i get a wider tire than stock? how wide is a stock tire anyway? i want to go about an inch or two wider.
a little help on tire sizes...
stock is usually 215/70-15 for a passenger car, 225/70-15 for a police cruiser. On a 6.5" wide rim I've run 255/60-15 tires, which is about inch or so wider than stock, on 7" rims I believe Tom (GMGT) ran 275/60-15 tires. Because you want wider tires I assume you're looking for more control on the road? I've had very good experience with the 245/60-15 tires mounted on 7" rims, car was stable and maneuvarable as hell. For the summer I'm thinking of getting some 8" rims and H-rated 255/50-15 tires, now that'll keep me nicely glued to the road
You don't want to go too terribly wide otherwise the tire will have a poor contact patch unless you run with low air pressure. 245-60-15 is probably about the biggest I'd go on a stock 7" wheel. I run a 225/60/16 H rated tire on my car and I'm very pleased with the handling and traction.86 Lincoln Town Car (Galactica).
Easy thing to do is go to tirerack.com and look at tire specs. They have all the info on what tire fits on what wheel and stuff. A 225/70 or a 235/60 would be a decent size, but personally, a stock 215 will handle better on a 7" wide wheel, better than a 225 on a 6.5" wheel.Builder/Owner of Badass Panther Wagons
Originally posted by merkman86okay, so lets say i wanted my tires just an inch wider on stock turbine wheels... what size would they be? im not familiar with how tire sizes workhow about two inches wider?
two inches wider is asking for a lot. If you have a 7" wide wheel, Id get 245/60/15 and be done, you'll be happy with them.
Stock turbines are 6.5" wide and Id put 235/60 on those. lemme dig up a pic...
Only thing 70 profile tires are good for is filling up wheel well spacePete ::::>>> resident LED addict and CFI defector LED bulb replacements
this is 235/60/15 front and 235/70/15 rear (fresh variable waggin springs in the rear)
Last edited by 85crownHPP; 02-15-2007, 05:28 AM.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
Know this as well, i don't know where you are, but if it rains a lot, do not get wider than 245s. I drive withe 245/60 front, and 255/60 rear, but my wheels are 8.5" wide. I have noticed a significant increase in the amount of hydroplaning that happens at speed. But that's just a price you pay.Last edited by Blaze86Vic; 02-15-2007, 07:38 PM.
Originally posted by Blaze86VicKnow this as well, i don't know where you are, but if it rains a lot, do not get wider than 245s. I drive withe 245/60 front, and 255/60 rear, but my wheels are 835" wide. I have noticed a significant increase in the amount of hydroplaning that happens at speed. But that's just a price you pay.http://secondhandracing.com/Home.aspx
LOL, I ran bald autocross tires without any isses in the rain....Currently run 255's without any issues in the rain. You two have tires that don't work well in the rain. The drag radials are a given for poor wet performance.Builder/Owner of Badass Panther Wagons
the used, slightly dry rotten 5/32" tread goodyear eagle RSA's I had had excellent wet traction. Almost as good as dry... but I didnt push it real hard when dry either.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
235/70 -15 all the way around, on stock wheels. Handles good in the rain or dry road. Don't ask about snow!89 CV LX 225/60 x 16 tires, CC819 rear springs, Front & rear sway bar, trans & PS cooler from 90 cop car. KYB shocks, F-150 on rear. Dual Exhaust w/ H pipe. Dark brown door panels, carpet, steering wheel, trim parts from a 87 Mer GM. Power front buckets from 96 Jeep Cherokee. LED'S front & rear. 3G Alt from a 97 Taurus wagon 3.0. Electric fan. Rear axle from a 97 PI 3.27 with disk brakes. Headlight relays.
I never have a problem with my 10.50 in the rain. EVER. But my tires are more suited for wet weather performance.1989 Grand Marquis LS
Originally posted by mrltdLOL, I ran bald autocross tires without any isses in the rain....Currently run 255's without any issues in the rain. You two have tires that don't work well in the rain. The drag radials are a given for poor wet performance.
You also have an extra 400lbs on your rear tires. Those of us with base model light panthers have a little weight issue in the rear.
