Are there any chemicals that will eat away rubber, but not harm metal? Since I'm unable to burn out the suspension bushings due to my location, I'm looking for other options.
rubber eating chemical?
power steering fluid, look what it does to the swaybar bushings.....
Using a drill bit, drill into the rubber, the reverse around the inside of the shell. That will usually tear it up so you can get the removal startedBuilder/Owner of Badass Panther Wagons
why cant you burn them??? apartment rules? lol... actually you may be able to heat them up enough without making them burn to just push them out... one of mine started bubbling and had halfway popped itself out before it caught big flame...Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
drill, maybe with a hole saw. to cut through from each side. Should get a pretty good amount of the bushing seperated from the shell before it bottoms out.86 Lincoln Town Car (Galactica).
I thought WD-40 ate up rubber a bit, that might help.sigpic
1986 Grand Marquis LS 2 Door
Acetone will eat through plastic, and I think it might break down the rubber as well.
Maybe acid would work too; just have to be careful.**1976 Ford F-150 4WD: 360, 4 spd, 3.50s, factory A/C, 4" lift, Bilsteins, US Indy Mags, 35s Cruiser
Originally posted by MeLikeyStripperChicks View PostIt does, I used it on my control arm bushings, combined with a 4" hunting knife, worked good.sigpic
Originally posted by P72Ford View PostAcetone will eat through plastic, and I think it might break down the rubber as well.
we have used a drill method like gadget mentioned. swiss cheese the bushing and dig the chunks out with a screwdriver.http://secondhandracing.com/Home.aspx
Originally posted by DuceAnAHalf View Postacid would eat the metal before the rubber.
Acid would be my last choice, as there are other remedies that would probably be much safer and effective.**1976 Ford F-150 4WD: 360, 4 spd, 3.50s, factory A/C, 4" lift, Bilsteins, US Indy Mags, 35s Cruiser
Originally posted by P72Ford View PostAcid has to be fairly concentrated to eat away at metal though (or the metal has to be exposed for a long duration of time, which may be the case in this instance). I wouldn't try anything that corrosive.
Acid would be my last choice, as there are other remedies that would probably be much safer and effective.http://secondhandracing.com/Home.aspx
ky eats rubber
Nitric acid eats rubber like no one's business, but I think it will eat the steel as well. I'll ask my chemistry professor.1990 Country Squire - under restoration
Originally posted by Tiggie View PostNitric acid eats rubber like no one's business, but I think it will eat the steel as well. I'll ask my chemistry professor.
after wards you can add the nitric acid to all sorts of stuff to make explosiveshttp://secondhandracing.com/Home.aspx
