you know the style of wheel bearing on our GM's, with the nut that you tighten just right.
I've always had a little doubt about these. First time it was too tight, second time I followed someone's advice and ended up with a wiggling bearing too soon (just retightened).
Thought I'd gotten it down-- just tighten all the way until there's no slack to squeeze all the play and grease out, then back off just a little and give a firm but slight 20 ft-lb nudge.
But honestly, I've only ever had to do this on my own cars-- never saw them in the shop I worked at for a time, too old to see any more![:)](https://www.grandmarq.net/vb/core/images/smilies/smile.gif)
Well, so we have this 1989 mercury tracer. Rear bearings are done this way, too.
There was some play, not gross, but not acceptable either. We were on a budget so last November, the drums looked fine-- we just did new bearings and new seal on the old drums We had $1500 in other expenses for other parts at the time.
20,000 miles and 11 months later, suddenly in the past day the left rear bearing just fragmented. Started getting a noise, jacked the car up, noticed extreme slop, pulled it apart and the outer tapered roller bearing was missing 2 rollers and with 3 others cracked.
Bad luck?
cheap chinese bearing?
or something I could have done wrong last november to cause premature wear?
Bad luck?
