Is this normal for these cars? The heat gets nice n' hot, but I swear that the "low" setting on my Caravan throws more air than the "high" setting on the Marq.
Weak blower motor
Feel around to see where the air is going. Mine doesn't move a lot of air unless its on dash, one of the air doors is jammed or something. Even on dash, it doesn't exactly move enough air to blow your hat off.86 Lincoln Town Car (Galactica).
mine blows weak in the defrost setting but pretty decent on floor/mix/vent. hhmmmmmLast edited by 85crownHPP; 12-22-2006, 02:44 AM.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
Strange. I noticed that the blower resistor is obviously bad because low and medium settings don't work. This shouldn't be the problem though.
Oh well!
It seems that it blows weak on defrost and the floor vents, too. I've been having a lot of weird electrical problems lately. I'll live with it. Just sucks when I've got the driver's window cracked when I'm having a smoke, I'm freezing my ass off!1988 Mercury Grand Marquis
Brakestand machine.
Weak floor air could be a problem with the thermal blower lockout switch. This is the vacuum/electro doodad inline with one of your heater hoses. Try jumping the two wires in the connector together and see if that gives you better floor blower. Also, while you are freesing with the window down, is it producing good heat and just not blowing it? or blowing lukewarm air?? Since I pulled the vacuum hose off the blend door (right behind the glovebox) I have to crack a window to keep from burning up.Originally posted by MarquisMalarkyIt seems that it blows weak on defrost and the floor vents, too... Just sucks when I've got the driver's window cracked when I'm having a smoke, I'm freezing my ass off!Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
