10amp should be plenty - they dont need much current at all.
gadget pretty much summed it up.
For mine I used the cig lighter wiring (has its own fuse) for power and ground, and tapped into the ashtray light wire for illumination.
The hole I used was almost clear from under the dash, just the edge of a peice of insulation in the way.
edit: I forgot to mention my key on source... all I did was tap the key-on wire for the radio, and used that to trigger the relay thats powered by the cig lighter wiring.
I also have a bridged barrier strip you can see in there... since i have many many accessories![Smile](https://www.grandmarq.net/vb/core/images/smilies/biggrin.gif)
* this pic is old (pre-console) but the electronics in the ashtray cavity are the same*
![](http://memimage.cardomain.net/member_images/4/web/316000-316999/316132_233_full.jpg)
