Could be worse. Not all that long ago, I was afraid to take off my TFI distributor cap to see if there was moisture inside, becuase I thought it might mess with the timing!
I don't have a clue what that means I know what the distributor is/looks like, but....
The short of it is that the distributor cap is very easy to remove and replace without incident, because it's just held on by a couple big clips and has a notch in the rim that makes it impossible to reinstall in the wrong position. Actually swapping caps takes a little more care because you have to make sure the wires stay in the correct order.
don't wanna start a new thread just for this, but, is it normal for mileage to slightly improve? i'm talking very slightly..1mpg better maybe. if that.
Also: This should be inspirational to folks that didn't think they could do something like swap alternators...if an imbecile like myself can do it, anybody can! I can't believe I was so scared to do something so simple.
Some people have what it takes and they just dont know it
How can we tell if we have big alternator bracket??? Cause i got a sable with 3.8l in back yard we getting rid of wondering if its work pulling alt.
* 65amp rating
* small frame, 7" mounting hole cL to cL (center line)
3G alternator (130 amp) for our swap
* comes in large and small frame sizes
* small frame can be found stock in 1995 5.0L Mustang
* large frame can be found stock in 1993 3.8L Taurus
* the small frame is a direct physical fit for the 65A 2G
* the large frame is a direct fit for the 100A externally regulated units.
* the large frame unit can be used in place of the small 2G if the appropriate bracket is used.
* the 3G also comes in 75A, 95A flavors. (Same case sizes)
* large 3G runs cooler simply due to larger size
* internal fan
geuss what my fair friend I have a heated windshield(iirc its the one with wierd yellow tint at top) hahaah
