i got the battery installed last night and today i was checking to see what works and what does not.
works:
Hazards
Ignition switch turns the starter
Horn
High beams
semi-works:
turn signals ( the turn on but they do not flash)
does not work:
headlights ( i believe i cut the power wires on the backside of the fuse panel)
i believe this is the reason that the parking lights do not work either.
works:
Hazards
Horn
High beams
semi-works:
does not work:
or just braggin that you fucked up your own car by cuttin wires.
