Does it make any difference what size cable I use for the chassis ground? I know 1ga is probably overkill but that's all they had in stock in the length I needed with ring terminals already on em
marine terminals
1ga sure won't hurt anything, but yes, it is a touch overkill. You'll have a good connection though!Originally posted by gadget73There is nothing more permanent than a temporary fix.
Cool. Looks kind of funny, the EEC ground is like 12ga at most, chassis and block grounds are both 1ga and the + battery cables (solenoid to battery, battery to fuse, fuse to alternator) are 4ga
It looks like the block ground is only maybe 8ga and the chassis is like 10ga.
goddamn marine terminals are convenient!
I need to get some sort of corrosion inhibitor - is such a product made? I don't wanna replace corroded terminals and cables in a few monthssigpic
You can buy a protective spray, or slather them in dielectric grease.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
Originally posted by 1990LTD View Postgoddamn marine terminals are convenient!Originally posted by gadget73There is nothing more permanent than a temporary fix.
might as well do the big three with the largest gauge thatll work easily while youre at it.1988 MGM GS - Preferred Equipment Package 172A; InstaClear
1994 MGM GS Montigua
2002 Mustang GT Coupe
