I am not very "electrically" inclined, and I wanted to do the headlamp relay mod so I sourced a pre-fabricated wiring harness. I purchased the harness through Daniel Stern Lighting and it was made by Susquehanna Motorsports out of Fleetwood, PA. Customer service through Daniel Stern was excelent and the quality of the harness seems good as well. I took some quick pics of the harness, going to try and install tomorrow. The harness uses one of the existing headlamp plugs as the actuator for the relays and all the connectors are ceramic as well. I like it because I don't have to cut into any wiring, and should I sell the car I can take the harness out and use it in a different one.
Headlamp wiring harness
If it can be told, how much did this cost you, in total? Bobby
There's no rules about that kinda thing here, lol. I post links-to and prices-of stuff i find all the time.
I also like it when things wind up plug-and play. I did pretty much the same thing, but i harvested a headlight harness from a junkyard car to use. I just wanted to get them re-wired so the high/low current doesn't flow through the headlight switch anymore. If you are upgrading headlights to something more powerful it's not a bad idea to upgrade wiring and connectors too.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
Originally posted by 85crownHPP View PostThere's no rules about that kinda thing here, lol. I post links-to and prices-of stuff i find all the time.
Cool. I just hardwired mine in.~David~
I made my own, but it was plug and play. If my harness fails horribly, all I have to do is plug the stock headlight connectors back in, and we're back to 1986 again. It made a very nice improvement though. I measured the voltage before and after, and it was over 2 volts if I remember correctly.
WHen I was looking, I couldn't find one that seemed to be of decent quality and was the type I needed, so I did it myself. I tried a pre-made one on my Mark VII, and had lots of problems with it. The relays melted down, so I upgraded them. It kept burning them out or burning out headlights, so I removed it and went back to stock.86 Lincoln Town Car (Galactica).
Maybe a "write up" for the job??? Would make a nice "sticky"!! Bobby
