Ahh it happens.
Daniel Stern marker flash mod
Originally posted by 1990LTD View Postthhanks man!
- snip both black ground wires on 2 of the outermost lights, butt splice them together
- bare a centimeter or so of wire on the one i just made
- bare the same amount on the signal wire (green on d/s...don't know about p/s) for the innermost light
- connect them with another length of wire
I just keep re-checking to make sure I have everything because it sounds too simple to be as cool as it issigpic
I dont understand...but all you were supposed to do was connect the ground wires from the two 194 bulbs (talking about one side here) to the signal wire of the big inner most bulb.~David~
That is exactly what I did
Could my drls be interfering?sigpic
WTF, I just changed it back to the way it was and those lights still don't work. I'm havin great luck todaysigpic
Check the fuses and flasher. You probabably blew the fuse or flasher at some point in the repair.
Did you hook the bulb end or the car end of the ground wires to the turn signal wire?Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
Nope, turns out I had everything just fine.
A piece of wire was grounding out against the body where I couldn't see it.sigpic
I guess this mod is only good for the Crown Vic. I'm pretty sure the GM only has the one blinker/marker bulb up front? I could do it to the rear markers2002 Mercury Grand Marquis GS 4.6L V8, 1988 Mercury Grand Marquis GS 5.0L V8, 1979 Lincoln Mark V 6.6L V8, 1977 Lincoln Continental 7.5L V8, 1999 Chevrolet Suburban LT 5.7L V8
I can't remember how many were on my Mercurys. I know that's the case with Town Cars.
check it out:
