I have 2 12" Orion Xtr's putting out 500W apiece, As of now after i fix my speaker problem im thinking of putting a new amp in right now i have some generic Nitro 1000w amp could I go more so it hits harder?
Subwoofer question
you need to match the RMS watts of the subs to the RMS watts of the amp. any more amp will only make them distort.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
Not really true I could use way more power and not have speakers disort. I have ran a single JL 8w6( capable of handling 300 watts) with over 500 w and had no problem. Distortion is commonly known as clipping when the amplifier is cutting off the tops of the sound waves, causing distortion. It is way bad for a speaker. Distortion is what idiots think is music around here. plus speakers do not have RMS which is power output speaker do not have power output. They have power handling. To get bass you do not have to match the power handling of a speaker.
Tim2000 Ford Crown Victoria
84 Lincoln Town car signature, R.I.P
85 Ford LTD Crown Victoria 2 door performance project
89 Lincoln town car: RIP
89 Crown Victoria LX 2002 USACi sound quality world champion RIP
1990 Mercury Grand Marquis LS
1994 Mercury Grand Marquis (sold)
2004 Mercury Marauder. owned for a week then got screwed by the dealer
Originally posted by over2tonsofFun View PostNot really true I could use way more power and not have speakers disort. I have ran a single JL 8w6( capable of handling 300 watts) with over 500 w and had no problem. ...... plus speakers do not have RMS which is power output speaker do not have power output. They have power handling. To get bass you do not have to match the power handling of a speaker.
Tim
Then why do speakers have an RMS rating on the box??? Amp are rated with RMS power outputs, and speakers are rated with RMS power "handling"...
These ratings are what the speaker can handle without distortion - these are the laws of physics... your personal experiences have probably miseld you.
Sure you can use a more powerfull amp than what a sub is rated for - you just cant deliver its full power, or it will distort after a certain point.
And sure you can "get bass" without matching power ratings, but this person is asking about finding an amp thats a good match for his subs.
Like I said, to make sure you get the most out of your subs, you match RMS ratings - anymore power will go to waste, unless of course you are planning to upgrade. Or unless you can use a 4ohm load instead of a 2 or 1 ohm load, in which case you will get even less distortion.
A more powerfull amp is not going to give him any more bass that his $$$ will notice, unless he is using a gawd awefull amp. Now, a better amp of the same power just may... but this is a whole 'nother discussion.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
His original question was:
...could I go more so it hits harder?
85crownHPP, you have a PM :smirk:Last edited by torquelover; 03-11-2008, 12:19 AM.
Well yes, if thats a max rating on the amp and RMS on the subs, you could stand to have some more amp. I was assuming those were both RMS values, since those are the only ones worth comparing.
I like SQ tootight bass is no good if the rest of the frequencies arent as powerful and crisp.
RMS is max that a sub will handle on a test bench. Like a 200w booster, with a 14 guage power wire. physically impossible. RMS power is just that rated power. that is why they came up with the new grading system for amps
You actually answered your own question, speakers have a rating not a power output. Which is what was stated. You can distort a speaker being run at RMS just as well as any other way. It is they way the amp is set. It is better to have more head room for better sound output.
Why if you would get the best sound out of a system when everything is matched. The winningest car in Car audio, Richard Clark's Grand National where it is running 6 speakers with 6 amps each with a 1500w RMS, Alpine 3545.
