Front and Rear Door Lock Actuators
    I am looking to replace the door lock actuators on my '91 CV. Are the front and rear actuators the same (rod extender and actuator)? I am seeing conflicting information in the parts catalogs. I am going to buy OEM actuators so I am not going to get a bag of multiple styles of rods like the aftermarket actuators come with. Some of the catalogs say they are the same part number, but those also come with an assortment of rods so I'm not sure if I bought 4 OEM actuators of the same part if they will all work.
    '89 XR7 5 Speed
    '95 SC 5 Speed
    '91 Crown Vic P72 351W
    '93 SC AOD
    Without consulting my bible I'd say either tear your own car down and look at them or go gung-ho on a junkyard car to see.
      The actuators are the same. The rods, which you can swap from one actuator to another, are not the same.
      Vic
        Got it. I forgot you could swap the rods from the actuator. Thanks for the response.
        '89 XR7 5 Speed
        '95 SC 5 Speed
        '93 SC AOD
          I usually shop around for cheap OEM actuators for some oddball application and switch the rods if needed. Last pair I got were 30 bucks each, marketed for an 84 Topaz or something. Happily, it looks to be the same damn lock actuator that my Mark VII uses.
            Not a bad idea. Are they all pretty much the same for Fords across the board from the early 80's to the end of the box era? They all look like they have the same round body, but with different rods. It looks like when they switched to the aero-Vic they switched over to those rectangular box actuators (which is ironic now that I think about it).
            '89 XR7 5 Speed
            '95 SC 5 Speed
            '93 SC AOD
              yep. Same actuator, different rod. The plugs and all are the same. Only real difference is that some have plastic brackets and some have metal, but that seems to be more a year by year thing. No idea if it makes any real difference. Can't say I've had problems with the brackets being the fail point.
              I would actually like to figure how to easily fit aero lock actuators if only because they are more available than the old ones. They also don't seem to seize and fail as much.
                I actually have a couple of aero actuators (used) that I bought years back not knowing they wouldn't fit. I couldn't figure out how to get the extension rod out (different than the older cylindrical actuators) so I put them back on the shelf to collect more dust.
                '89 XR7 5 Speed
                '95 SC 5 Speed
                '93 SC AOD
                  Check out GM_Guy's thread: http://www.grandmarq.net/vb/showthre...=Lock+Actuator
                  Vic
                    Good to see another old school name that I remember. Welcome back!
                      Thanks. Been gone for a long time. Looking to fix up some issues on my car. I remember when you just started this site. Looks like it has grown quite a bit in the last 8-9 years.
                      '89 XR7 5 Speed
                      '95 SC 5 Speed
                      '93 SC AOD
