I always liked those style valve covers.
1985 Crown Victorious HPP *DUW*
thanks mangs!
I always thought these are the perfect valve covers for any smallblock carbed (or cfi) ford...
they are aftermarket style bling with OEM quality goodness!!
I forgot to include this bit of info:
I found a twist-in ford oil cap/breather at the junkyard and my breather hose worked to hook that breather up to the air cleaner. Its likely that you could stick a breather elbow into an oil cap and have the exact same thing, but since I found this I just used it.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
i know!!! all the extra cfi stuff ruins it... you dont even want to see what became of the vacuum solenoids from the old valve covers, lets say the driver fenderwell is a little more crowded now... its all kinda hiding under the air snorkle though. 3 more years untill she can be registered as an antique...
and jeese that breather cap is dirty... I was loosing the daystar by the end of the swap so I just wiped it off... didnt see the crud in the nooks n crannies... maybe Ill clean it and paint it... maybe.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
eh, I wouldnt call it ram air... the driver side tube opens up just behind the headlights, and the passenger side one tucks down to a flap I cut open in the rubber thing between the radiator and radiator supportPete ::::>>> resident LED addict and CFI defector LED bulb replacements
no!!!! its my only ammo when I have to convince some one that indeed it is considered EFI as well as CFI for CFI is a type of EFI !!!!!Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Technically, Pete's right. The fuel IS being injected, and it IS electronically controlled, so by definition it IS EFI. But still...it just seems so...carburetory. If that wasn't a word before, it is now. :evil:
yea what's going on in petes world?
not a whole terrible lot, I gotta get pics of the power trunk pulldown in here...
as far as updates, she sits under a 10x20 canopy and is driven across town/highway at least once a week, while I gather parts for big brakes and some sefi HO mojo.
Yes, she will loose the CFI (one day... soon? - It depends how fast certain people get certain HO parts to me ). I figure, if you're going to remove the CFI to do engine work, why put it back on????
I also need to do some more rust delaying and think of ways to get money for a good paintjob/body de-rustingPete ::::>>> resident LED addict and CFI defector LED bulb replacements
the passenger front window motor quit again, so I replaced it again, this time with cheap new chineese. First I did bushings in that one (2003), then used brushes (2004). Then a re-man from Fisher(2006).
Went ahead and replaced the siezing PDL actuator again too with new chineese. First time I replaced it with a working used one... the new chineese actuator I put in the drivers door looked like good quality, so I went ahead and bought more for both cars.
Both chineese parts for this door were together under 50 bux...
big brakes soon... soon...Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
gadget builds the best power window motors
