those are nasty looking freeze plugs. Hope you changed the others while you were in there. You know they're not far behind. I use brass freeze plugs just for that reason. And I do hope you're not running straight water in there.
That rust wasn't the plug that was in the block scary enough. And no its not straight water.
1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
2006 P71, 1988 Bronco II, 1986 Baby LTD(5.0 & T5 swap in progress), 1976 16' Hobie Cat, 12' AquaFinn http://www.cardomain.com/ride/2651997UPDATED 20100826
Still waiting on the duel feed fuel line to come in but a little eye candy for now.
I worry about what judges can see a shows. If its hidden like that I try not to sweat it.
